Community Member
MOH CCM 4.1(3)
We have a CCM 4.x in our lab, change site and the MOH of telephony stop of the play. I restart de TFTP and MOH Server but nothing!
We are using CISCO2801 like MGCP gateway.
Peterson
1 ACCEPTED SOLUTION
Gold
Re: MOH CCM 4.1(3)
MoH by default does not support G729, but you can configure CallManager such that it can stream G.729 as well. To do this you need to go to Service Parameters for Ip Voice Media Streaming Application and for the field "Supported MOH Codecs ", check G729 along with G711.
Hope this helps
Re: MOH CCM 4.1(3)
Did you change ip address on your callmanager ?
Community Member
Re: MOH CCM 4.1(3)
No it's same.
The ccm is tftp server too(lab)
The telephony is registered, the calls is ok.
I create a connection by ISDN by Siemens and the telephony "see" the telephony of Siemens side, but when I press hold button, only a beep sound.
Re: MOH CCM 4.1(3)
make sure the MRGL, MRGs in use with the phones in question, have a MOH server listed.
Community Member
Re: MOH CCM 4.1(3)
See attachments
Community Member
Re: MOH CCM 4.1(3)
See attachments 2
Community Member
Re: MOH CCM 4.1(3)
See attachments 3
Community Member
Re: MOH CCM 4.1(3)
I found the problem.
The MOH don't play in G.729, only in G.711.
I don't know why! The MOH Audio Source is ok to G.729.
Gold
Re: MOH CCM 4.1(3)
Hope this helps
155
