MoH CCME
ricardorojas123
Hi I have a CCME version 7 installed, the problem is that the music on hold only is heard from the pstn caller, the music on hold in the internal phones registered in the call manager express is not heard. Why ?
telephony-service
moh music-on-hold.au
7 Replies 7
Rob Huffman
Hi Ricardo,
You will need to use IP Multicast. Have a look;
Restrictions for Music on Hold
IP phones do not support multicast at 224.x.x.x addresses.
Cisco Unified CME 3.3 and earlier versions do not support MOH for local Cisco Unified CME phones that are on hold with other Cisco Unified CME phones; these parties hear a periodic repeating tone instead.
Cisco Unified CME 4.0 and later versions support MOH for internal calls only if the multicast moh command is used to enable the flow of packets to the subnet on which the phones are located.
Internal extensions that are connected through an analog voice gateway (Cisco VG 224) or through a WAN (remote extensions) do not hear MOH on internal calls.
Multicast MOH is not supported on a phone if the phone is configured with the mtp command or the paging-dn command with the unicast keyword.
Here is how to set this up :)
From this excellent CME doc;
Configuring Music on Hold
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html
Hope this helps!
Rob
Ok, thanks Rob.
But, What is the range of multicast addresses that can be used?
Hi Ricardo ,
this link is a good guide to Multicast address IP .
http://www.tcpipguide.com/free/t_IPMulticastAddressing.htm
The address for the internal/local use must be 239.0.0.0 /255.0.0.0
Administratively-scoped (local) multicast addresse
I hope to help you .
Dear All
i have CME 4.0 on 3825 Version 12.4(9)T7.
I configured everything as you can find below but still no Moh internal between Phones !
CONFIG (Version=4.0(0))
Version 4.0(0)
Cisco Unified CallManager Express
For on-line documentation please see:
http://www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
ip source-address 10.226.24.151 port 2000
no auto-reg-ephone
load 7970 TERM70.7-0-3-0S
load 7960-7940 P0030702T023
max-ephones 168
max-dn 336
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 5
voicemail 50998
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line mode is single
phone service videoCapability 1
time-format 12
date-format dd-mm-yy
timezone 5 Pacific Standard/Daylight Time
secondary-dialtone 9
call-forward pattern .T
call-forward system redirecting-expanded
transfer-pattern 9.T
keepalive 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout ringin-callerid 8
caller-id name-only: enable
system message REACH
web admin system name cisco secret 5 web admin customer name Customer
edit DN through Web: enabled.
edit TIME through web: enabled.
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp 7960 Apr 26 2009 10:01:24
transfer-system full-consult dss
multicast moh 239.10.16.4 port 2000
route 10.226.24.151
local directory service: enabled.
CME#show inventory
NAME: "3825 chassis", DESCR: "3825 chassis"
PID: CISCO3825 , VID: V05 , SN: FTX1309A23C
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN: FOC1304102H
NAME: "Integrated Service Engine for Modular and Integrated Services Routers on Slot 1", DESCR: "Integrated Service Engine for Modular and Integr
ated Services Routers"
PID: NME-CUE , VID: V01 , SN: FOC12512G15
NAME: "High Density Voice2 Network module with on board one port interface on Slot 2", DESCR: "High Density Voice2 Network module with on board
one port interface "
PID: NM-HDV2-1T1/E1 , VID: V05 , SN: FOC13034FSF
NAME: "On-board VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 2 SubSlot 1", DESCR: "On-board VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Mu
ltiflex Trunk - T1/E1"
PID: , VID: 1.1, SN:
please note that there is no E1-Pri installed now.
i am just using it for internal.
What do you hear when you put two IP phones on hold? Tone on Hold or silence (dead air)?
If tone on hold, your moh configuration is not correct.
If dead air, there's a multicast routing configuration problem.
Try this under telephony-services:
multicast moh 239.10.16.16 port 2000 route 192.168.1.1 172.16.1.1 ***where those IP's are the default gateways of the phone subnet***
If your phones are on a different subnet, you may have to enable multicast routing.
I think that there was a limitation that the multicast port-number must be an even port number, and it has to be in the range between 16384 and 32768.
Check if this would help.
Vasil
