MoH file... Cannot delete it...
I have a MOH file that was uploaded to a CUCM 7.1 server that contained spaces (wk_3 radio calls).  I have tried to delete the file from the "MOH Audio File Management" tab, but it will not delete.  No errors are reported.  Anybody have an idea how to either get rid of the file or change the file name to something without spaces, which will hopefully allow me to delete it?
Re: MoH file... Cannot delete it...
I am not sure about this solution but try:
check the dependency records
Are you doing as instructed in the link?
Deleting a Music On Hold Audio File
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmfeat/fsmoh.html#wp1111477
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
249
