MOH file
hii,
i want to chang my MOH tune ao that i am upload new file but error is there
"Unmapped Exception The entity name must immediately follow the '&' in the entity reference"
so what happen plz sugest me................
Re: MOH file
jay,
See if this helps or not,
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008084ec31.shtml
It's not exactly the same symptoms encountered by you but the steps might help.
Also, the file must be in .wav format, file size should be reasonable.
Abhijit Das - UCB Pharma..
Hall of Fame Super Red
Re: MOH file
Hi Jayesh,
Have a look at this good post from Mahesh @ Cisco Systems that details the 5.1.1 Bug that you are hitting along with the ES notes for the required fix;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddf7556/0#selected_message
Hope this helps!
Rob
Please remember to rate helpful posts.....
163
