==MOH Fixed Audio Source Configuration example==
Hello folks, I found the follow links for those installation:
http://cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803f3a9f.html#wp1028403
My question is: is its the only steps that I need to do or I will need to be careful to do?
Another things, I have to do this in work hour or after hours?
Thanks a lot..!!
1 REPLY
Green
Re: ==MOH Fixed Audio Source Configuration example==
Yes, excellent guide.
You can do it afterhours since when adding MOH servers to MRG involve restarting devices which are using those Media resources.
195
