MOH from Flash Issue between IOS Versions
Hi Guy’s!
Have a little trouble regarding local multicast MOH for router flash via incoming PSTN calls…..
Basically, there are three sites (small branches) where they have their own BRI’s for incoming calls… When they are putting people on hold, it is resorting to “Tone On Hold” opposed to MOH from the flash etc…
The this is that two of the three sites have this problem and the third site works. The only difference with the sites that don’t work, is a later IOS version (Cisco IOS Software, 2801 Software (C2801-ADVIPSERVICESK9-M), Version 15.1(4)M3, RELEASE SOFTWARE (fc1). The single branch where it does work is IOS version (Cisco IOS Software, 2801 Software (C2801-ADVIPSERVICESK9-M), Version 15.0(1)M5, RELEASE SOFTWARE (fc2).
These seems to be configured the same as far as I can see but has anyone know any issues between the IOS versions?
Any help much appreciated!
Everyone's tags (3)
Blue
Hi James,
What digit you have entered in " Music On Hold (MOH) Server Configuration "
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
I've seen on different images different way of writing
for example
telephony-service
moh music-on-hold.au
moh "music-on-hold.au"
moh "flash:/music-on-hold.au"
Rate helpful posts.
We don't have telephony-service enabled (either for the working or non working)....
Cheers!
Hi Ronak,
Maximum hops set to "10"
Cheers!
Blue
Any Specific reason to kep it as 10. try to change it to 1 and see issues gets resolves.
Ronak Patel
Rate helpful posts.
Hi ,
Yeah, changing from 10 to 1 made no difference.
Cheers!
Blue
HI
after changing the setting. Did you restarted Ip voice media services.
Ronak patel
rate helpful posts.
Yes, reset after change but still no good....
Still working on this in the background.
Re: MOH from Flash Issue between IOS Versions
- Please share the config of non working router.
- on cucm share a snapshot of moh server page
- what is the codec between moh and non-working branch
541
