MOH in SRST - not multicast
antoinemeunier
Just want to be sure before implementation:
Is it possible to configure MOH for SRST-mode, not using the multicast option?
I would configure the call-manager-fallback: moh song.au
and then put this audio file in the flash.
Is this correct?
Best regards,
Antoine
Chris Deren
No, only MMOH is going to work.
HTH,
Chris
Chris Deren
HTH,
Chris
