MOH is not working
Hi  Experts
Please find the below config
kindly help me to resolve the issue .
ccm-manager music-on-hold
telephony-service
sdspfarm units 4
sdspfarm transcode sessions 1
sdspfarm tag 1 KSA-txd
sdspfarm tag 2 KSA-cnf
no privacy
conference hardware
pin 123456 override
max-ephones 35
max-dn 60
ip source-address 192.168.16.9 port 2000
max-redirect 5
system message CISCO CME
time-zone 31
date-format dd-mm-yy
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh "music-on-hold.au"
multicast moh 239.10.16.4 port 2000
web admin system name admin secret 5 $1$/VBP$OUhQSDtLDHQeMO8kkpWUF1
transfer-system full-consult
transfer-pattern 9.T
secondary-dialtone 9
create cnf-files version-stamp 7960 Jul 31 2012 12:44:39
Everyone's tags (2)
Re: MOH is not working
Added this two lines:
moh music-on-hold.au
multicast moh 239.1.1.55 port 2100
is the file at the flash:\music-on-hold.au
Please remember to rate useful posts clicking on the stars below. Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo. ___________________________________________ LinkedIn Profile: do.linkedin.com/in/leosalcie
make sure you put the following command in your config:
This command enables the multicast music-on-hold (MOH) feature on a voice gateway.
If you want to bind the Multicast MOH to a specific interface, use the following command
ccm-manager music-on-hold bind
eg.
ccm-manager music-on-hold bind loopback 0
Hope this helps.
Saurabh
366
