09-24-2014 07:12 PM - edited 03-17-2019 12:17 AM
I have the following output, as you can see the Incoming Interface is blank, my H323 binding is configured in the Loopback1. I also have the problem is, the customer has no T1 trunk, his using fxo ports for incoming and outgoing calls, when i call from out the PSTN and he puts me on hold I don't hear the music, but between internal users they can hear the audio.
location-2821#show ccm-manager music-on-hold Current active multicast sessions : 1 Multicast RTP port Packets Call Codec Incoming Address number in/out id Interface =================================================================== 239.1.1.1 16384 162/162 58134 g711ulaw
09-25-2014 05:55 AM
Can you please post all relevant configuration?
Chris
09-26-2014 06:42 AM
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 192.120.0.80 port 2000
max-ephones 58
max-dn 120 dual-line
transfer-pattern .T
moh "music-on-hold.au"
multicast moh 239.1.1.1 port 16384 route 192.120.133.1 192.120.0.80
time-format 24
date-format dd-mm-yy
192.120.133.1 --h323 binding
192.120.0.80 --f0/0
!#show ccm-manager music-on-hold
239.1.1.10 16384 0/0 1531 g711ulaw
Thanks.
09-25-2014 07:03 AM
Verify MoH is bound to an interface... "ccm-manager music-on-hold bind Loopback#"
The MoH file exists on the router?
Verify you have the statement in the call-manager-fallback portion of the config:
"multicast moh 239.1.1.1 port ##### route x.x.x.x x.x.x.x"
Also, if you have uploaded, or changed the moh file in anyway before first disabling MoH you will have to restart the router to allow MoH to function properly.
