Community Member
Moh Live Feed using E/M card
Hi All,
I'm wondering if anyone can help me as I'm struggling to get MoH Live feed working through my SRST 3845 router. Config is as follows
voice-port 0/2/0
auto-cut-through
operation 4-wire
signal immediate
dial-peer voice 7777 pots
destination-pattern 7777
port 0/2/0
call-manager-fallback
max-conferences 8
moh-live dn-number 3333 out-call 7777
multicast moh 239.1.1.1 port 16384 route 10.158.81.1 10.255.255.254
show ephone summary:
ephone-1 Mac:001D.457E.A205 TCP socket:[1] activeLine:0 REGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:010.155.34.3 7961
keepalive 28 1:2 CM Fallback
ephone-2 Mac:001D.4595.7D6A TCP socket:[2] activeLine:0 REGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:010.155.34.2 7961
keepalive 25 1:3 CM Fallback
Max 240, Registered 2, Unregistered 0, Deceased 0, Sockets 2
ephone_send_packet process switched 0
Max Conferences 12 with 0 active (8 allowed)
Skinny Music On Hold Status
Active MOH clients 0 (max 820), Media Clients 0, B-ACD Clients 0
No MOH file loaded
MoH Live feed configured from DN 1
MoH Live feed: Good signal
Moh multicast on 239.1.1.1 port 16384 via 10.158.81.1
via 10.255.255.254
I have left and right speaker on the jack plug wired to 600 ohm PAM 10 the output is wired to pins 3 & 6 on the RJ45 E/M connection
Any Ideas?
1 REPLY
Community Member
Re: Moh Live Feed using E/M card
Hi All,
I now have this working it was a Multicast issue. My SRST router and my Phones are on serperate VLAN's and my L3 Switch wasn't passing the multicast traffic.
PIM command on my VLAN interfaces worked
226
