MoH live feed via E&M card
Rob McCarty
CUCM 10.5, 2911 router with E&M card
I understand the basics of making this work with multcast.  Blocking the source from the CUCM so the phones listen to the router instead.
Does this work on MGCP?  Will my E&M card work not being programmed into the CUCM?  Does my voip dial-peer even work in MGCP?  I did this years and years ago with an H323 srst GW but a little different setup and want to make sure before I get to far.
Jaime Valencia
No, this does not work with MGCP, you still need to do the SRST as MOH source config + live feed config to get this.
java
if this helps, please rate
Jaime Valencia
java
So I can keep the router as MGCP in CM but add SRST and it will use the dialpeer?
Yes
Appendix B: Integrating Cisco Unified Communications Manager and Cisco Unified SRST to Use Cisco Unified SRST as a Multicast MOH Resource
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/SCCP_and_SIP_SRST_Admin_Guide/srst_appendix_b.html
java
