Community Member
MoH. Multicast. Don't play continuously
Hi all,
We have a cluster of CUCM 8 and we have configured the MoH in multicast.
In a branch office works fine but in another we have the next issue when a ipphone put a PSTN call on hold the music is heard ok but only one time, it's not play continuously. This is courious because the MoH is configured in multicast. When the music is stoped the party in hold listen silence.
PbxGw-1#sh ccm-manager music-on-hold
Current active multicast sessions : 1
Multicast       RTP port   Packets       Call   Codec    Incoming
Address         number     in/out        id              Interface
239.1.1.1         16384   460/460          69   g711ulaw  BV96
PbxGw-1#
dkAalPbxGw-1#sh ccm-manager music-on-hold
239.1.1.1         16384   569/569          69   g711ulaw  BV96
PbxGw-1#sh ccm-manager music-on-hold   <<< In this point is when the music is stopped.
Current active multicast sessions : 0
Other traces:
PbxGw-1#show call active voice | include RemoteMedia
RemoteMediaIPAddress=239.1.1.1
RemoteMediaPort=16384
RemoteMediaIPAddress=10.100.251.141    <<< In this point is when the music is stopped. This @ip is the cucm server
RemoteMediaPort=4000
I have the next configuration in the gateway:
interface Loopback1
   ip address 10.1.1.1 255.255.255.255
ccm-manager music-on-hold bind BV96
telephony-service
  moh flash:holdmusic.wav
  multicast moh 239.1.1.1 port 16384 route <@ip bridge> 10.1.1.1
In MoH Audio Source I have checked "Play continuously" and "Allow Multi-casting"
Alberto
Everyone's tags (2)
Blue
Let me know full configuration under telephony-service.
You do not have max-ephones and  max-dn command.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Community Member
Hi Ronak,
First, thank you.
telephony-service
srst mode auto-provision none
srst ephone template 1
srst ephone description Cisco Unified CME SRST Fallback  : Sep 20 2011 10:45:40
srst dn template 2
srst dn line-mode dual-octo
max-ephones 200
max-dn 400 preference 5
ip source-address 10.105.245.10 port 2000
max-redirect 20
no service directed-pickup
system message "FallBack-Mode" (CME-as-SRST)
cnf-file location flash:
cnf-file perphone
time-zone 23
time-format 24
date-format dd-mm-yy
voicemail 899451211
max-conferences 8 gain -6
hunt-group logout HLog
multicast moh 239.1.1.1 port 16384 route 10.105.245.10 10.1.1.1
transfer-system full-consult
secondary-dialtone 0
create cnf-files version-stamp 7960 Apr 12 2011 11:41:49
Alberto
570
