MOH no more resources available
I have setup multicast MOH to remote sites using the routers to provide the MOH, this has worked for some time ok, but now I get the MOHNoMoreResorcesAvailable message in the event log when somebody is put on hold.
I reload the Callmanager that has the MOH server, it seems to work once then get messages again
the unicast MOH is ok( uses another Callmanager)
anybody any ideas
Gold
Re: MOH no more resources available
U should use RTMT, Perfmon to check if the sessions are being released or not after MoH is being played
thats not the problem, I configured 250 Multicast streams, and there is still 250 streams available, just the outof resources counter increments eveytime
Gold
If u see MoH resources available, then the phones/device which is initiating MoH does not have access to the MoH server which has multicast enabled. Can u collect CCM Traces and IP Voice Media Streaming App Detailed traces for a test call ??
468
