MOH not working CME 9.5 for PSTN
Have the following configuration:
Cisco 2921 Router with SRE-710 running CME 9.5
No calls are working when using the MOH file that we had been using on a 2821 with CME 8.6 with no problems
Have following commands in place
voice-port 0/0/0:23
 local-alerting
 timeouts interdigit 3
ccm-manager music-on-hold
telephony-service
moh "flash0:/butler5.au"
 multicast moh 239.1.1.1 port 16384
phones have multicast moh enabled and default code for ephone is g722-64
Is it possible this is getting tied up by my switches (Cisco 2960S)?
All calls are getting tone on hold.
Everyone's tags (1)
1 ACCEPTED SOLUTION
The link below should help
The link below should help you out.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmemoh.html
Yosh
HTH Regards, Yosh
Bronze
 Hi, Check answer in this
Check answer in this post, might be of help.
https://supportforums.cisco.com/discussion/11421511/cant-hear-moh-pstn-help
hikindly find the below:-1
hi
1-multicast moh 239.1.1.1 port 16384 route x.x.x.x y.y.y.y  where x.x.x.x the ip address of a loopback address and y.y.y.y the ip address of your voice vlan ip address.
2- can you test the MOH internally between two internal extensions .
3-Add the following under telephony-service
multicast-moh
4-Test without  " . use the below
moh flash0:butler5.au
5- yes , 2960 support IGMP and it is enabled by default.
6- Final thing , you have to do it , if nothing work from above. enable ip pim dense-mode under voice vlan interface and loopback
please rate all useful information
Made the changes and still
Made the changes and still have the tone on hold, below is config changes:
interface Loopback10
 ip address 192.168.117.1 255.255.255.0
 ip pim dense-mode
 ip nat inside
 ip virtual-reassembly in
interface Tunnel1
 no ip address
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description -LAN-SW-LAUNCH-INFO-GE 0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.1
interface GigabitEthernet0/0.10
interface GigabitEthernet0/0.20
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/1.1
 description Management
 encapsulation dot1Q 1 native
 ip address 172.20.0.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.10
 description Data
 encapsulation dot1Q 10
 ip nat inside
interface GigabitEthernet0/1.20
 description Voice
 encapsulation dot1Q 20
 ip address 172.20.10.1 255.255.255.0
 ip pim dense-mode
 ip nat inside
 ip policy route-map policymap
interface GigabitEthernet0/2
 ip address
 ip nat outside
 ip inspect firewall out
 duplex auto
 speed auto
 crypto map CMAP_1
interface Serial0/0/0:23
 no ip address
 encapsulation hdlc
 isdn switch-type primary-ni
 isdn incoming-voice voice
 isdn bchan-number-order ascending
 no isdn outgoing ie redirecting-number
 no cdp enable
interface SM1/0
 ip unnumbered GigabitEthernet0/1.20
 service-module ip address 172.20.10.2 255.255.255.0
 !Application: CUE Running on SM
 service-module ip default-gateway 172.20.10.1
interface SM1/1
 description Internal switch interface connected to Service Module
 no ip address
interface Vlan1
 no ip address
interface Vif1
 ip address 192.168.6.1 255.255.255.0
 ip pim sparse-dense-mode
Here is telephony service:
multicast moh 239.1.1.1 port 16384  route 192.168.117.1  172.20.10.1
One thing I forgot to mention is that MOH works fine when call is parked but not when put on hold.
Thank you
hello1)can you add the below:
hello
1)can you add the below:-
router(config)#ip multticast-routing
and enable  ip pim sparse-dense mode instead of dense mode under voice and loopback interface.
ip multicast-routing was
ip multicast-routing was already enabled
The sparse-dense mode did not work
I have attached the primary config. thank you again
+5 Islam for the good
+5 Islam for the good information.
I just want to add a few things.
1 - You need to type the following command "ccm-manager music-on-hold"
2 - You don't need to turn on "ip multicast-routing" and definitely don't turn on "ip pim dense-mode". If you wanted to use "pim" use "sparse-mode". The reason you don't need to turn on "ip-multicast" is because you are already routing the traffic to the specific networks "multicast moh 239.1.1.1 port 16384  route 192.168.117.1  172.20.10.1"
3 - Also do a"show ip mroute" to make sure that you're using the correct "IP multicast address'. Remember that Cisoc IOS routers MOH only uses G711ulaw.
Yosh
HTH Regards, Yosh
Here is ip mroute info
BEC2921#show ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group,
       G - Received BGP C-Mroute, g - Sent BGP C-Mroute,
       Q - Received BGP S-A Route, q - Sent BGP S-A Route,
       V - RD & Vector, v - Vector
Outgoing interface flags: H - Hardware switched, A - Assert winner
 Timers: Uptime/Expires
 Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 224.0.1.40), 5d19h/00:02:06, RP 0.0.0.0, flags: DCL
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    Loopback0, Forward/Sparse-Dense, 5d19h/stopped
That's my bad, I meant to say
That's my bad, I meant to say run a "show ip mroute" while you are on hold and only if you kept the "ip multicast-routing" on. As a side note, try changing the codec on your phone to G711ulaw and place a call between the phones, to verify that MOH is working. If it's not working make sure that the location of the MOH file is correct.
Yosh
HTH Regards, Yosh
I thought that MOH is not
I thought that MOH is not used when internal phones are placed on hold, commands with phone on hold:
(*, 224.0.1.40), 5d19h/00:02:57, RP 0.0.0.0, flags: DCL
BEC2921#dir flash0:/
Directory of flash0:/
  314  -rw-      185180   Jun 6 2013 20:34:48 -04:00  butler5.au
Yosh
HTH Regards, Yosh
The solution was that the
The solution was that the G722-64 codec needed to be added to the dsp farm.  Make sure you shutdown the dspfarm first to add the codec.  Thank you again for all your help.
hi1-+5 for yosh as usual for
hi
1-+5 for yosh as usual for his great explanation. I need to add something for multicast-routing we use this command to allow transfer multicast packets between routers , l3 devices  , host (source) to send packets to a group of hosts (receivers) anywhere within the IP network by using a special form of IP address called the IP multicast group address and to allow pim protocol work properly  under interfaces. As you mentioned if i define a static multicast and define source , group and we have only one cme , ip multicast-routing enable or disable won't affect .
2-can you replace ccm-manager music-on-hold  to ccm-manager music-on-hold bind "voice vlan interface"
3- do "debug ccm-manager music-on-hold" and catch logs
Can you share with us
router#show ccm-manager music-on-hold
So I have gotten internal moh
So I have gotten internal moh calls working using an moh-group.  I still do not have pstn calls working and just get tone on-hold for the pstn calls. When on hold I do not get any logs from ccm-manager and current active multicast sessions are 0.
409
