Community Member
MoH on 28xx series
Is it possible to configure router with dsp as MOH to work with Callmanager 6.0 Enterprise?
Community Member
Re: MoH on 28xx series
it's a recommended way for MOH streaming at remote sites:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/moh.html#wp1043896
As far as I understand it, DSPs are not involved in process of streaming.
Hope this helps.
Community Member
Is is possible under SRST licence only??
Community Member
yes, as the mentioned document states:
"An SRST license is required regardless of whether the SRST functionality will actually be used. The license is required because the configuration for streaming MoH from branch router flash is done under the SRST configuration mode and, even if SRST functionality will not be used, at least one max-ephones and one max-dn must be configured."
Hall of Fame Super Gold
If MoH is from file, not DSP are necessary.
Live MoH requires an E&M port, and DSP.
152
