Community Member
MoH on CME File Size
I have a CME running v12.4 and the customer wishes to change the MoH. Is there a file size limit (besides the hard limit imposed by the available flash memory)?
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: MoH on CME File Size
Hi Jamie,
There is no restriction on the file size other than you already noted :) Here is a good reference doc;
Cisco Unified Communications Manager Express System Administrator Guide
Configuring Music on Hold
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00807dab90.html
Hope this helps!
Rob
Hi Jamie,
Hope this helps!
Rob
Community Member
Thank you very much.
583
