MOH on CUCME
I install and configure a new CUCME 8.6 on a 2951 router. The MOH is not working for internal and external calls.
My question is do i need to configure the ip pim dense on the router and switch? Is mandatory?
My config of MOH:
telephony-service
moh flash:/CME/music-on-hold.au
multicast moh 239.10.16.4 port 2000
Im using this guide:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wp1021176
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
MOH on CUCME
You don't need to configure anything.
The default works fine.
MOH on CUCME
MOH on CUCME
Paolo i dont nee to config the multicast too correct?
only the moh music-on-hold.au under telephony-service..
MOH on CUCME
Correct.
MOH on CUCME
Thanks i´ll try this tomorrow and i´ll let you know!
MOH on CUCME
Thanks Paolo
I put the default command, my moh file is under this directory that i create (/CME)
And the MOH is working!
Thanks!
MOH on CUCME
You're welcome, thank you for the nice rating, and good luck!
432
