MOH ON EXTERNAL INCOMING CALL
HI .
I HAVE A MOH PROBLEM FOR EXTERNAL INCOMING CALL ?
FOR THE INTERNAL CALL . THE MOH IS WORKING
PLEASE WOULD SOMEONE TO HELP
THANKS IN ADVANCE
HICHAM
Have you already checked your MRGLs and that all MOH servers have the MOH files??
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
What are you using as your MOH source?
Is this problem happening in the same office as where your MOH source resides, or a branch office?
What CUCM software/hardware are you running?
Jonathan Beardsley CCNA Voice; MCITP Telecom & Network Administrator DECOSIMO
199
