MOH on Router Flash
Attached is the network diagram. Also attached is my LAB config for a spoke Site B.
We are running CUCM 8.6 on Site A. Site B run SRST CME.
I have 2 MOH audio source loaded on the publisher and only 1 is setup for multicast.
MOH Server, MRG and MRGL is setup and applied on both Device Pool, IP Phones and Site B gateway.
Site B has been loaded with MOH wav file in flash0 and is the same file configured in CUCM for multicast.
Site B phones when one is place on hold, I can still hear the Server configure MOH under Service Parameter and not the MOH loaded in Site B flash.
Here are the show commands on Site B when I place a call on hold with the Site B network. Also same result when I call over PSTN, I hear the Server configure MOH instead of SIte B flash MOH.
OC-MHO-GW#show ccm-manager music-on-hold
Current active multicast sessions : 0
OC-MHO-GW#show ephone summary
hairpin_block:
Max 100, Registered 0, Unregistered 0, Deceased 0 High Water Mark 101, Sockets 3
ephone_send_packet process switched 0
Standby socket list (no registered device):
[2]: 10.190.0.24 50365    [3]: 10.190.0.22 50974
[5]: 10.190.0.26 52892
Max Conferences 77 with 0 active (77 allowed)
Skinny Music On Hold Status - group 0
Active MOH clients 0 (max 1300), Media Clients 0, B-ACD Clients 0
File Servcorp_MOH.ULAW.alaw.ULAW.wav (cached) type WAVE Media_Payload_G711Ulaw64k 160 bytes
Moh multicast 239.1.1.1 port 16384 route 10.190.0.1
File play position 46 file type 2 current type 2
Play offset 6042606, Write offset 0,File start 46 end 6747402
File buffer at 1A86E2E4, buffer size 6752000
RTP ssrc F1B4BD45 timestamp_offset DC0 position E746 reposition 0
Max process service interval 515973 (last 54247)
Min interval 20001, missed 435973 run 0 (us)
moh_process_service counter 253902
Max Media process interval 592799 (last 534113) run 0 (us)
File system max access time 5390 (us) (last 2931) with late-reads 0
0 clients interrupt service, 0 process level
0 no-conversion, 0 a-to-mu, 0 mu-to-a
0 packets serviced at interrupt, 0 at process
Media Client Tx: 0     Xcode Tx: 0
OC-MHO-GW#show voice moh-group
call-manager-fallback
moh Servcorp_MOH.ULAW.alaw.ULAW.wav
moh-file-buffer 8000 (Kb)
=== no voice moh-groups configured ===
Everyone's tags (3)
1 REPLY
Hi,Is the Multicast box
Is the Multicast box checked on MoH source, MoH server and MRG?
What is the max hop setting on MOH server enabled for multicast? Try to set it to 1.
Manish
- Do rate helpful posts -
584
