MOH on router
We are currently running a HUB and SPOKE IP Telephony model for the 1st time.
CUCM 7.1.5 pub, sub and CUC located at Site A. Site B has a 2Mb dedicated link to Site A for voice traffic only such as phone registration and VOIP. No other traffic apart from telephony traverse through this link. Each site has its own Voice Gateway and we use H323 and ISDN E1. Phones on Site B gets its IP Address from the local router using option 150 (Site A CUCM IP).
Phones on Site B have been experiencing bad static MOH and I was wondering if theres a guide to load the MOH on the local router instead of CUCM on the remote Site A?
What format does the MOH file have to be on for this to work?
Are there any other solution apart from changing the region on the Site B device pool to G711 to fix MOH?
Everyone's tags (2)
Blue
MOH on router
HI
You can use router as MOH source and this will reduce WAN BW utilisation.  Below link shows you the exact confi in details.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802d1c31.html
regards
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
MOH on router
Thanks.
Ill read up on it now and test on my network. Ill let you know of outcome.
Blue
MOH on router
HI
If it helps please rate helpful posts by clicking stars below the answer.
Ronak Patel
Re: MOH on router
I have made the changes and applied the settings on both CUCM and SITE B router (also running SRST CME).
CUCM is also configure with multicast MOH using port number increment multicast.
Added MOH Server to MRG
Added MRG to MRGL
Applied MRGL to both phones on Site B aswell as the Site B router.
SRST works perfect.
Heres my config on the Site B router:
tftp-server flash:MOH.ULAW.alaw.ULAW.wav
ccm-manager fallback-mgcp
ccm-manager music-on-hold
telephony-service
srst mode auto-provision none
srst dn template 1
srst dn line-mode dual
max-ephones 265
max-dn 600
ip source-address 10.190.0.1 port 2000
no caller-id name-only
system message "SRST Mode: WAN DOWN"
cnf-file location flash:
load 7942 SCCP42.9-2-1SR2S.loads
time-zone 47
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 6565001999 extension-length 12 extension-pattern 96666002222#
voicemail 96666002222#
max-conferences 8 gain -6
call-forward system redirecting-expanded
moh "flash:/MOH.ULAW.alaw.ULAW.wav"
multicast moh 239.1.1.1 port 16384 route 10.190.0.1
transfer-system full-consult
secondary-dialtone 0
ephone-dn-template  1
call-forward busy 96666002222#
call-forward noan 96666002222# timeout 5
ephone-dn  7  octo-line
number 88101
preference 8
call-forward noan 96666002222 timeout 10
ephone-dn  500  octo-line
number 8888 secondary 6565001...
name V
call-forward all 88101
ephone  8
device-security-mode none
mac-address 0022.9003.E713
button  1:7
OC-MHO-GW#sh flash
-#- --length-- -----date/time------ path
1      4678202 Jun 26 2012 14:06:38 +10:00 apps42.9-2-1ES4.sbn
2         2903 Jan 17 2012 03:27:14 +11:00 cpconfig-39xx.cfg
3      3000320 Jan 17 2012 03:27:28 +11:00 cpexpress.tar
4         1038 Jan 17 2012 03:27:38 +11:00 home.shtml
5       122880 Jan 17 2012 03:27:48 +11:00 home.tar
6      1697952 Jan 17 2012 03:28:04 +11:00 securedesktop-ios-3.1.1.45-k9.pkg
7       415956 Jan 17 2012 03:28:14 +11:00 sslclient-win-1.1.4.176.pkg
8     78470692 Jun 26 2012 11:48:52 +10:00 c3900-universalk9-mz.SPA.152-3.T.bin
9         1237 Apr 19 2012 19:10:10 +10:00 FOC1551120N_20120419014514500.lic
10           0 Jun 26 2012 12:43:12 +10:00 its
11           0 Jun 26 2012 12:43:12 +10:00 its/vrf1
12          58 Aug 3 2012 12:11:48 +10:00 its/SEPDEFAULT.cnf
13      575464 Jun 26 2012 14:06:54 +10:00 cnu42.9-2-1ES4.sbn
14     2209742 Jun 26 2012 14:07:02 +10:00 cvm42sccp.9-2-1ES4.sbn
15      361359 Jun 26 2012 14:07:10 +10:00 dsp42.9-2-1ES4.sbn
16     1759963 Jun 26 2012 14:07:18 +10:00 jar42sccp.9-2-1ES4.sbn
17         662 Jun 26 2012 14:07:24 +10:00 SCCP42.9-2-1SR2S.loads
18         662 Jun 26 2012 14:07:34 +10:00 term42.default.loads
19         662 Jun 26 2012 14:07:40 +10:00 term62.default.loads
20     6747402 Aug 3 2012 10:53:52 +10:00 MOH.wav
21     6747402 Aug 3 2012 11:03:46 +10:00 MOH.ULAW.alaw.ULAW.wav
149659648 bytes available (106848256 bytes used)
During  normal mode (Phones register to central CUCM) when internal calls  between two phones are place on hold, its blank. During SRST mode, same  type of calls, I hear beeps.
Any idea?
Super Bronze
MOH on router
Firstly when in normal mode:
If you hear silence, that means that CUCM has told the phone to listen to mcast MoH. You should be able to browse to the phone and look at the 'streams' to see what mcast address the phone is listening to.
The key thing is to ensure you have configured MoH on CUCM so that the correct audio stream and server are assigned to the phone - each stream has a different mcast address or port number, so if a different one is assigned the phone will be told to listen to 239.1.1.2 or 239.1.1.1 with a different port. The same applies for different codecs, e.g. g729 region will get a different address/port than the same audio source in a g711 region.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Re: MOH on router
During on HOLD, codec is G711 but there is no tx rx between the two phones within the region.
Ive also check the phone webpage on streaming statistics and during on MOH, stream status is Active (phone that was place on hold) but nothing on multicast IP or Port.
Re: MOH on router
Hi again,
I have followed a few guides in Cisco and Google. Most require a loopback interface.
Also when I issue the command, this is what I get
OC-MHO-GW#show ccm-manager music-on-hold
Current active multicast sessions : 0
OC-MHO-GW#show voice moh-group
telephony-service
internal-call moh-group (not configured)
moh flash0:/MOH.ULAW.alaw.ULAW.wav
moh-file-buffer 2000 (Kb)
Moh multicast 239.1.1.1 port 16384 route 10.70.255.82 10.190.0.1 10.190.1.1
voice moh-group 1
description (not configured)
multicast moh (not configured)
extension-range (none configured)
=== Total of 1 voice moh-group ===
OC-MHO-GW#sh ephone moh
Skinny Music On Hold Status - group 0
Active MOH clients 0 (max 1300), Media Clients 0, B-ACD Clients 0
File flash0:MOH.ULAW.alaw.ULAW.wav (not cached) type WAVE Media_Payload_G711Ulaw64k 160 bytes
File play position 263266 file type 2 current type 2
Play offset 800, Write offset 16000,File start 46 end 6747402
File buffer at 12A8E9F8, buffer size 64000
RTP ssrc 2D3BDB55 timestamp_offset DC0 position AC6A reposition 0
Max process service interval 511983 (last 43134)
Min interval 20000, missed 431983 run 0 (us)
moh_process_service counter 245508
Max Media process interval 547781 (last 511131) run 0 (us)
File system max access time 5627 (us) (last 2960) with late-reads 0
0 clients interrupt service, 0 process level
0 no-conversion, 0 a-to-mu, 0 mu-to-a
0 packets serviced at interrupt, 0 at process
Media Client Tx: 0     Xcode Tx: 0
Skinny Music On Hold Status - group 1
No MOH file loaded
File play position 0 file type 0 current type 0
Play offset 0, Write offset 0,File start 0 end 2147483647
File buffer at 0, buffer size 0
RTP ssrc 0 timestamp_offset 0 position 0 reposition 0
Max process service interval 0 (last 0)
Min interval -1, missed 0 run 0 (us)
moh_process_service counter 0
Max Media process interval 0 (last 0) run 0 (us)
File system max access time 0 (us) (last 0) with late-reads 0
Re: MOH on router
I got the following debug output. Any idea? Local to local phones dont work when phones are registered to remote CUCM. I have also check the wav files, I have encoded to CCITT ulaw 8,000kHz, 8 Bit.
005139: Aug  7 04:40:49.936: SkinnySetMohFilename set type to MOH_TYPE_INVALID for moh-group 0
005140: Aug  7 04:40:49.936: SkinnyStopMoh with no active clients in moh-group 0
005141: Aug  7 04:40:50.268: SkinnyStartMoh: moh-group 0
005142: Aug  7 04:40:50.268: skinny_open_moh_play for NULL file (live feed)
005143: Aug  7 04:40:50.268: skinny_open_moh_play set type to MOH_TYPE_LIVE
005144: Aug  7 04:40:50.268: MOH buffer allocated at 1BBCF7FC
005145: Aug  7 04:40:50.268: skinny_open_moh_play read header OK
005146: Aug  7 04:40:50.268: Starting read server with play-offset 0 write-offset 0
005147: Aug  7 04:40:50.288: skinny_get_moh_from_codec no file, no moh_live_feed
005148: Aug  7 04:40:50.464: SkinnyStartMoh: moh-group 0
005149: Aug  7 04:40:50.464: flash0:/MOH_ulaw.wav: MOH WAVE file
005150: Aug  7 04:40:50.464: skinny_open_moh_play set type to 2
005151: Aug  7 04:40:50.468:  5249 4646 02F5 6600 5741 5645 666D 7420
005152: Aug  7 04:40:50.468:  1200 0000 0700 0100 401F 0000 401F 0000
005153: Aug  7 04:40:50.468:  0100 0800 0000 6461 7461 DCF4 6600 FEFE
005154: Aug  7 04:40:50.468:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005155: Aug  7 04:40:50.468:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005156: Aug  7 04:40:50.468:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005157: Aug  7 04:40:50.468:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005158: Aug  7 04:40:50.468:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005159: Aug  7 04:40:50.468:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005160: Aug  7 04:40:50.468:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005161: Aug  7 04:40:50.468:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005162: Aug  7 04:40:50.468:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005163: Aug  7 04:40:50.468:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005164: Aug  7 04:40:50.468:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005165: Aug  7 04:40:50.468:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005166: Aug  7 04:40:50.468:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005167: Aug  7 04:40:50.468:
005168: Aug  7 04:40:50.468: WAVE file processing Found RIFF
005169: Aug  7 04:40:50.468: WAVE file processing Found WAVE
005170: Aug  7 04:40:50.468: WAVE file processing Found fmt
005171: Aug  7 04:40:50.468: WAVE file codec Media_Payload_G711Ulaw64k
005172: Aug  7 04:40:50.468: WAVE file processing Found data
005173: Aug  7 04:40:50.468: WAVE file data start at 46 end at 6747402
005174: Aug  7 04:40:50.468: MOH read file header type WAVE start 46 end 6747402
005175: Aug  7 04:40:50.468: Moh-group 0 pre-read block 0 at write-offset 0 from flash0:/MOH_ulaw.wav offset 46
005176: Aug  7 04:40:50.468: Moh-group 0 pre-read block 1 at write-offset 8000 from flash0:/MOH_ulaw.wav offset 8046
005177: Aug  7 04:40:50.472: Moh-group 0 pre-read block 2 at write-offset 16000 from flash0:/MOH_ulaw.wav offset 16046
005178: Aug  7 04:40:50.476: Moh-group 0 pre-read block 3 at write-offset 24000 from flash0:/MOH_ulaw.wav offset 24046
005179: Aug  7 04:40:50.476: skinny_open_moh_play: Starting read server for moh-group 0 with play-offset 0 write-offset 32000
005180: Aug  7 04:40:50.768: SkinnyStartMoh: moh-group 0
005181: Aug  7 04:40:50.768: flash0:/MOH_ulaw.wav: MOH WAVE file
005182: Aug  7 04:40:50.768: skinny_open_moh_play set type to 2
005183: Aug  7 04:40:50.768:  5249 4646 02F5 6600 5741 5645 666D 7420
005184: Aug  7 04:40:50.768:  1200 0000 0700 0100 401F 0000 401F 0000
005185: Aug  7 04:40:50.768:  0100 0800 0000 6461 7461 DCF4 6600 FEFE
005186: Aug  7 04:40:50.768:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005187: Aug  7 04:40:50.768:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005188: Aug  7 04:40:50.768:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005189: Aug  7 04:40:50.768:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005190: Aug  7 04:40:50.768:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005191: Aug  7 04:40:50.768:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005192: Aug  7 04:40:50.768:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005193: Aug  7 04:40:50.768:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005194: Aug  7 04:40:50.768:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005195: Aug  7 04:40:50.768:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005196: Aug  7 04:40:50.768:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005197: Aug  7 04:40:50.768:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005198: Aug  7 04:40:50.768:  FEFE FEFE FEFE FEFE FEFE FEFE FEFE FEFE
005199: Aug  7 04:40:50.768:
005200: Aug  7 04:40:50.768: WAVE file processing Found RIFF
005201: Aug  7 04:40:50.768: WAVE file processing Found WAVE
005202: Aug  7 04:40:50.768: WAVE file processing Found fmt
005203: Aug  7 04:40:50.768: WAVE file codec Media_Payload_G711Ulaw64k
005204: Aug  7 04:40:50.768: WAVE file processing Found data
005205: Aug  7 04:40:50.768: WAVE file data start at 46 end at 6747402
005206: Aug  7 04:40:50.768: MOH read file header type WAVE start 46 end 6747402
005207: Aug  7 04:40:50.768: Moh-group 0 pre-read block 0 at write-offset 0 from flash0:/MOH_ulaw.wav offset 46
005208: Aug  7 04:40:50.772: Moh-group 0 pre-read block 1 at write-offset 8000 from flash0:/MOH_ulaw.wav offset 8046
OC-MHO-GW(config-telephony)#
005209: Aug  7 04:40:50.772: Moh-group 0 pre-read block 2 at write-offset 16000 from flash0:/MOH_ulaw.wav offset 16046
005210: Aug  7 04:40:50.776: Moh-group 0 pre-read block 3 at write-offset 24000 from flash0:/MOH_ulaw.wav offset 24046
005211: Aug  7 04:40:50.780: skinny_open_moh_play: Starting read server for moh-group 0 with play-offset 0 write-offset 32000
OC-MHO-GW#
005213: Aug  7 04:40:55.280: MoH route If GigabitEthernet0/1.900 ETHERNET 10.190.0.1 via ARP
File flash0:Servcorp_MOH.ULAW.alaw.ULAW.wav (not cached) type WAVE Media_Payload_G711Ulaw64k 160 bytes
Moh multicast 239.1.1.1 port 16384 route 10.190.0.1
File play position 912046 file type 2 current type 2
Play offset 58880, Write offset 16000,File start 46 end 6747402
RTP ssrc 2D3BDB55 timestamp_offset DC0 position 5C80 reposition 0
Max process service interval 511983 (last 44170)
Min interval 20021, missed 431983 run 0 (us)
moh_process_service counter 44061
Max Media process interval 530052 (last 500032) run 0 (us)
File system max access time 3073 (us) (last 3073) with late-reads 0
Re: MOH on router
I'm still stuck.
From phone to phone on the same network, I hear the CUCM MOH different MOH file to what is currently loaded on the Site B router flash.
There are 2 MOH loaded on the server but only one is set to multicast. Same MOH loaded on the flash.
2734
