MoH on SRST: ¿which music file should I load?
Hello team:
I managed to get the "SampleAudioSource" files from CUCM as suggested in the configuration guides in order to use them as music source on a SRST router configured for MoH service.
The "audio oriented" files I got from CUCM are the following:
SampleAudioSource.alaw.wav
SampleAudioSource.g729.wav
SampleAudioSource.ulaw.wav
SampleAudioSource.wb.wav
Question: ¿which of these is the right one to be loaded in the router´s flash?
Thanks a lot in advance,
Rogelio Alvez
2 ACCEPTED SOLUTIONS
Re: MoH on SRST: ¿which music file should I load?
That information is already explained in the config guide
Configuring Cisco Unified SRST for Multicast MOH from an Audio File
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/admin/srst/configuration/guide/srs_moh.html#wp1011698
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Bronze
Hi there,
The ulaw or alaw files are going to be ones that you want to use,
http://www.cisco.com/en/US/products/sw/voicesw/ps2169/products_configuration_guide_chapter09186a008066747c.html#wp1338028
regards,
Paul
(as Java said while I got my coffee, +5)
Message was edited by: Paul Reck
java
java
Bronze
Hi there,
regards,
Paul
463
