12-09-2013 09:09 AM - edited 03-16-2019 08:46 PM
CUCM System version: 9.1.1.21019-1
I uploaded a new Wav file as an announcement under the welcome greeting sample folder and now this opening file is playing when anyone in our system puts someone on hold.
All I did was upload this file. I can not seem to remove or delete that file either. I am wondering how or why this file seemed to attach itself to the begining of our MOH.
Any help is greatly appreciated.
Kevin
Solved! Go to Solution.
12-10-2013 07:02 AM
Hey Kevin,
Good to hear you are getting somewhere
It may be that you are hitting this bug for the periodic timer;
Make MOH so caller does not hear repeat ann immediately after greeting
Symptom:
Callers hear initial announcement then immediately hear periodic announcement regardless of periodic timer
Conditions:
Native Call Queuing
Workaround:
none
Cheers!
Rob
"When it comes to luck you make your own "
- Springsteen
12-09-2013 09:45 AM
Hi Kevin,
Is this set?
"Initial Announcement Played" set to 'Only for queued calls.'
Cheers!
Rob
- Springsteen
12-09-2013 10:09 AM
Yes it is and it still is playing
Kevin
12-09-2013 11:49 AM
Hi Kevin,
What happens if you disable your new "Custom" announcement?
Cheers!
Rob
- Springsteen
12-09-2013 11:51 AM
I might look at this bug as well;
Cannont delete custom announcements
Symptom:
There is no option to delete a custom announcement
Conditions:
CallManger 9.1
Custom announcements that are being used do not have an option to delete.
Workaround:
You can't delete a custom announcement that is in use. Disassociate the announcement from any Music On Hold Audio Servers and then you will be able to delete.
- Springsteen
12-09-2013 12:38 PM
Right now I am looking at restarting call manager as from everything I have been reading and from your input My thought is that call manager is stuck in this mode where it thinks it has to play that announcement first. I did change the service parameter to MOH source #2 and the MOH works fine. We have all our phones MOH settings default to none so it reverts back to the global service parameter setting .when I change it back to source #1 it acts up again. All the settings on source #1 and #2 match.
Kevin
12-10-2013 06:37 AM
Just a FYI,
Restarted call manager 1 services last night and checked it this morning when I got to work and still had the same problem. decided to restart the calmmanager services on the other 3 servers we have running and the problem went away.
Thanks for all replies and thoughts on this. Now I am back to trying to make the Que work in my hunt pilot. That is what started this mess in the first place.
I can get the initial announcement to play but the periodic announcement never kicks in.
12-10-2013 06:45 AM
Hi Kevin,
Thanks for the update (+5 )
Just curious, if you listen to the Initial Announcement all the way through
is the Periodic played immediately after ignoring the timers?
Cheers!
Rob
- Springsteen
12-10-2013 06:51 AM
OK,
Here is the latest, I think I must have a problem with the file I loaded as the periodic announcement as I can set one of the other canned announcements in there and it starts playing and yes Rob I did notice that it played the initial announcement and then right away played the periodic and then just the periodic at the correct timer setting.
12-10-2013 07:02 AM
Hey Kevin,
Symptom:
Conditions:
Native Call Queuing
Workaround:
none
Cheers!
Rob
- Springsteen
08-13-2014 01:17 PM
Custom announcements are stored in:
cm/tftpdata/CustomAnn/english_united_states/*
You cen delete them through CLI or tftp file mgmnt.
There needs to be an enhancement to manage these files IMHO
