MOH question
Is it possible for MOH to be played only for off-net calls instead of both off-net and on-net?
-Shikamaru
2 ACCEPTED SOLUTIONS
Re: MOH question
restrict the access to internal users not to be able to reach the MOH server, only leave the MOH server available to the GWs.
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Re: MOH question
Well you would still need to reference a MRGL in your device pool for conferencing, Xcode, MTP ect if you want to utilize those resources. you may just need to create a MRGL that excludes your MOH servers and add those to the gateway MRGLs only.
Re: MOH question
javalenc
java
Re: MOH question
Essentially would this be the same as taking the MOH server out of the MRGL for the phones?
Re: MOH question
javalenc,
It sound like your suggesting that the gateway be placed in a device pool that has access to the MRGL that references the MOH server. The divice pool that the phones are a part of would not reference one at all, correct?
-Shikamaru
Re: MOH question
Re: MOH question
Ahh, I see. Yeah, that makes sense.
-Shikamaru
135
