MoH setup on CCM 6.01
Hi All,
We have CCM 6.01 set up. I have uploaded MoH file under media Resources > MoH Audio File Management, after this I went to Media resources > MoH audio sources and set the streaming number for the MoH file.
I have since then reset MGRL and the Music on Hold server and still I get dead air on the phones when the hold button is pressed. Have I missed anything here.
Will rate helpful posts. thanks
VIP Super Bronze
Re: MoH setup on CCM 6.01
Naveen
Try and restart the Cisco IP Voice Media Streeming App service...
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
which codec are the phones expecting?? by default only G711Ulaw is enabled, if you need more codecs enable them under IPVMS service parameters
java
if this helps, please rate
java
www.cisco.com/go/pdi
228
