MOH Upload problem
Hi all,
I have problem uploading audio files for MoH. When I click Upload button, popup page hangs with blank page and stays that way.
Tried to reset MoH servers, streaming services... Nothing changes.
Has anyone encountered ths behavior?
Any help/hint/trick is appreciated.
Thank you
Vlad
MOH Upload problem
got the same problem with CUCM 8.6. We did an upgrade and evry thing works. Our System Version is System version: 8.6.1.21002-1 mybe you got an older one
MOH Upload problem
Hi Eike
Thank you for your input.
I have 8.5 version.
What is interesting is that on Pub server works like a charm, on the Sub is blank page.
MOH Upload problem
Hi, Can you tell me how you got the update? I have the same problem with 8.6 version.
Hall of Fame Super Red
MOH Upload problem
Hi Vlad,
I'm guessing it's related to these bugs;
Duplicate bug CSCtr18126 is superceded by CSCtr11072 The details are shown below.
CSCtr11072 - MOH Audio File may be slow or fail to upload
Description
Symptom:
MOH file upload fail, upload window does not update.
Conditions:
- CUCM 8.6.1.10000-43
- CUCM 8.6.1.20000-1
Workaround:
Additional Information
To recreate issue:
1) Open the MOH Audio file Management Select Upload file --  the upload file
window will pop up.
2) Select a file to upload.  The window get stuck, the file is not upload
Details
1st Found-in:                          (2)
8.6(1.10000.43), 8.6(1.20000.1)
Status:
Fixed
Last Modified:
Jan 19,2012
Fixed-in:                          (4)
8.6(2.10000.30), 8.6(1.98000.98), 8.6(1.98000.43)
8.6(1.21002.1)
Product:
Cisco Unified Communications Manager (CallManager)
Platform:
Dependent
Severity:
3 - moderate
Customer Reported:                          (81)
Related Bugs
CSCtr18126 : UI slow to refresh when uploading & deleting MOH files
Symptom:
When uploading MOH file the upload dialog window is not refreshed timely. Also when deleting an existing MOH file the "Music On Hold Audio File Management" does not update timely .
The times below were obtained with a a 63M audio file:
Upload:
8.6.1 = 3 min 10 sec
8.5.1 = 1 min 18 sec
Delete:
8.6.1 = 1 min 40 sec
8.5.1= 3 sec
Conditions:
Managing Music on Hold (MoH) files on versions:
8.6(1.10000-43)
8.6(1.20000-1)
Workaround:
Updates eventually succeed or fail. Retry with patience or upgrade to a version with the fix.
Cheers!
Rob
MOH Upload problem
Hi Rob,
Thanks for info, checked it, but I don't even get a browse button to choose file.
Cheers
V
MOH Upload problem
Have you reset your internet browser or tried using a different internet browser?
Yosh
HTH Regards, Yosh
MOH Upload problem
Sure Yosh,
IE 8 and 9, Firefox
Reset, clear history, cookies...
MOH Upload problem
Have you tried accessing the page from a different computer?
Yosh
HTH Regards, Yosh
MOH Upload problem
From 2 desktops, one server and 2 laptops
Vlad
MOH Upload problem
If all else fails you can try performing a reboot of the server during a maintenance window. I'll try to keep researching the issue and let you know if I find something.
Yosh
HTH Regards, Yosh
MOH Upload problem
I am restarting it tonight, actually.
Thank you Yosh. I'll update status, after restart.
Cheers
Vlad
MOH Upload problem
I am going to update to version 8.6.2a, is there a procedure to upgrade remotely?
Re: MOH Upload problem
Problem solved.
Actual problem was file system, had some bad blocks, common partition was read-only, done some recovery...
Audio file is uploaded.
Thank you everyone
Cheers
Vlad
MOH Upload problem
Hi Vlad
     I got the same problem with CUCM 8.5.1. Can you explain in more detail? how to solve the problem.
     Thank you.
Nuttawit W.
MOH Upload problem
No problem Nuttawit,
I had a situation where Pub CUCM was uploading flawlessly, but Sub Cucm was acting like explained earlier.
Actually, when I click Upload button, all I ever received was blank page, didn't even had a chance to see Browse button.
I decided to restart Sub server, and when I logged in to CLI, it showed that Common partition was read only, and I should check logs...use disaster recovery disk...
After restart it didn't managed to boot, because it reported some bad blocks, after I used recovery disk, it repaired bad blocks. Procedure is http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080b1f305.shtml#topic2
I restarted it again, and everything was back online, and I managed to upload audio file.
Cheers
Vlad
MOH Upload problem
Thank you Vlad.
Today i disable lan connection CUCM sub and upload file to CUCM pub.
It's work but when i enable lan connection CUCM sub. MOH can not play.
I guest i got CUCM database synchronization problem.
Do you have idea for this matter?
Nuttawit W.
Hello Nuttawit generate a database report on Cisco Unified Reporting the  database status must be good if not you can look on this troubleshooting  guide to see the reasons of your problem
https://supportforums.cisco.com/docs/DOC-13672
Regards.
MOH Upload problem
Thank you very much, I upgraded and now it's working fine. At the moment of upgrading I had a problem with the DB replication but once solved this, everthing seems to be OK, I uploaded the MOH file. Thank u so much !!!
1960
