MOH-USB-AUDIO
I am looking for a data sheet on this part and can not find one. Specifically, I need to know the input requirements for the live source. Is this a mic input or a line input? Is this an OEM of an existing product?
Re: MOH-USB-AUDIO
This is sound card and existing product. Check this link for more info: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/5x/50moh.html#wp1043752
This is your part number: MOH-USB-AUDIO= (USB music-on-hold adapter) more info near MCS servers:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/ps7299/product_data_sheet0900aecd805efb09.html
Re: MOH-USB-AUDIO
Thanks for the response, but does the MOH-USB-AUDIO require a "line out" from the connected audio source.
Re: MOH-USB-AUDIO
You want to provide MoH to your network not external output, so don't think you need anything more.
Re: MOH-USB-AUDIO
I have a customer using the MOH-USB-AUDIO device and it required mic level at the input. They used a line level to mic level attenuator.
Re: MOH-USB-AUDIO
Do you have details on the attenuator that they used that worked? I'm about to hook up a system for a customer using satellite radio and their receiver has a line level output.
Re: MOH-USB-AUDIO
Here is a link to the product at the manufacturer website.
http://www.radiodesignlabs.com/product.php?page=26
I see them on eBay quite regularly too. It should work fine for your purposes.
Re: MOH-USB-AUDIO
Hi Ross,
I believe the unit is a Sunix UTA3100 but have never seen one and do not know if it is modified. All the information states it is CUCM v5 onwards only, but the UTA3100 is Windows compatible so I am not sure if this is the device.
Frank
Re: MOH-USB-AUDIO
I installed one of these yesterday on an MCS-7835-I2 server running CUCM 7.1(2).
The adapter comes in a Cisco box but no Cisco specific instructions. A CD with various drivers is included as well as an A4 set of instructions that I have scanned and attached to this post.
The adapater is a SUNIX UTA3100B as stated in another post.
Installation was very simple. I plugged in the adapter and then plugged the headphone socket of my IPOD into the MIC input of the adapter using a 3.5mm - 3.5mm jack cable.
I enabled multicast on the fixed audio source, restarted the MoH server and then tested it.
It worked ok but there was some distortion so I turned down the volune on the IPOD to just over halfway (it had been set on full) and the quality was fine.
Only took ten minutes to do.
Re: MOH-USB-AUDIO
How do you go about downloading the pdf as it does not seem to be an attachment that I can download.
Re: MOH-USB-AUDIO
Hi Daryl,
The download works ok for me but I have copied the file to the link below as well.
http://www.jamesha.plus.com/USB-MOH-AUDIO=.pdf
Re: MOH-USB-AUDIO
1996
