MOH using .au file too loud
We are currently using the default MOH .au file on our UC500 system not the MOH port. Callers claim to hold
music is too loud. Where can we adjust the volume for this?
Diego
Re: MOH using .au file too loud
You have two options. You can use sound editing software to adjust the gain or you can simply go to http://www.cisco.com/cgi-bin/tablebuild.pl/ip-iostsp and download moh.zip. It already has couple of file adjusted at certain db levels.
rate this post if it helps.
Thank you. Sounds like a good idea.
Diego
257
