Bronze
Monitor Calls
What is the cheapest and easiest way to listen in on a phone call from another phone? We have a telerecruitment facility and the supervisors would like the ability to listen in on calls being made for training purposes.
Re: Monitor Calls
Mike,
You can certainly do this with CRS, but you might not need all of the capabilities in this product. Another option is IPcelerate's IPmonitor. Take a look at the following link.
http://www.ipcelerate.com/ipmonitor.html
Hope this helps.
Brandon
Bronze
Re: Monitor Calls
Can you point me in the direction of where I can find the documentation on how to do this with CRS? Thanks!
Re: Monitor Calls
Mike,
You will need a version of CRS that supports monitoring. For example, UCCE/IPCC Express Standard versions do not support monitoring. Beyond that, you will need to install this feature on your CRS server as indicated in the following document:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_4_0/installation/for_crs/404/crs404ig.pdf
You will also need to configure your network to support monitoring. See the following document:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801a62a8.shtml
Hope this helps.
Brandon
Bronze
Re: Monitor Calls
Any chance it works with CRA 3.5(3)?
Re: Monitor Calls
Yes, it does. The following document references monitoring with 3.x.
Hope this helps.
Brandon
221
