Most Specific Translation Pattern?
In CUCM, if two translation patterns are created, say 54XXX and 54275 which of the two will be picked if a user dials 54275? I would assume the most specific would be selected, I just need to be sure of this.
Thank you!
1 REPLY
CUCM always uses the BEST MATCH logic. So, yes.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
92
