02-26-2008 11:20 AM - edited 03-15-2019 09:05 AM
I have a new unity server I will be migrating to. If I move the port license from the old to new box, does the old box stop functioning? Or go to the demo '2 port' model? thanks
Solved! Go to Solution.
02-27-2008 12:45 AM
To migrate unity from one server to another Cisco Licensing will need to create you a new license key that matches the MAC address of the new server.
The license key will be generated on your existing Cisco Unity license, ports, users etc.
HTH.
Cheers
02-27-2008 12:45 AM
HTH.
Cheers
02-27-2008 07:26 AM
Thanks for the response. This helped alot. I just wanted to make sure I did not stop the old one from functioning when I moved the license over.
02-27-2008 09:37 AM
if you don't uninstall the license from the old server it will keep working, untill you uninstall and restart the server it won't go back to the default 2 ports
