Move CUPS to new Cluster
iptuser55
Level 6
Level 6
I have CUPS 7 assicated to a test cluster 7.x , can I and how much
effect is involved to re-point it to another Cluster running 6.1.2 or do I need to re-install it again
thanks
htluo
Level 9
Level 9
Double check compatibility guide.  If CUPS 7 is compatible with CUCM 6.1.2, it should be ok to switch cluster.
Michael
http://htluo.blogspot.com
htluo
Level 9
Level 9
Michael
Thanks, I went through the CUCM page on CUPS but it seems the customer does not know the Security Password which is stopping me moving from  one cluster to another
