moving CUCM DLU licenses bewteen clusters
Is it possible to move license files from 1 CUCM to another CUCM and from 1 CUUC to another CUUC?  There is a thought of moving a couple sites from 1 cluster to another CUCM 8.x to CUCM 8.x.  Cluster A was originally built with an original amount of DLUs and then a .lic file was added to allow the provisioning of about 200 phones - these 200 phones are the ones that will possibly be moved over to Cluster B.  Can the .lic file for the 200 phones be re-used on Cluster B to facilitate the move?
Thank you!
- Job 38:36
"I believe that the greatest work of God has not been in the miraculous, nor in the spectacular, incomprehensible Creation, but rather I believe it was accomplished on the Cross where He Himself purchased the redemption of His Bride... the salvation of m
1 ACCEPTED SOLUTION
Hi George
I think this will be impossible , because the licenses which you obtained for 200 Phones based on the MAC address of cluser A , so the same license file should be regenerated to obtain other .lic file by sending a request to licensing team to change the MAC address for the new cluser B.You can contact " licensing@cisco.com " for more information and on the mail type the sales order , end user details.
Thank you
please rate all useful information
Hi George,
I think it is possible by rehosting the PAK from old cluster to the new cluster.
I don't know if this is legal or not.
this is possible in version 9.X, since we have a license manager which host the licenses for all cluster.
Anas
please rate all the helpful posts
Hi George
Thank you
Thank you again for the detail.  The summary is that yes, the PAK can get regenerated but there may be a cost and delay.
Thank you!!!!
1 John 2:10, 4:8
295
