Moving CUE
We are moving from Call Manager 4 to CME 7. We will be configuring the new 3825 router with CME and also moving CUE from the old 3825 to the new 3825.
My question is - Will we be able to retain the current configuration and voicemails? Or will everything have to be reconfigured and the mailboxes recreated?
and - is this the only configuration needed:
interface Service-Engine1/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.71.48.15 255.255.252.0
service-module ip default-gateway 10.71.48.5
Thanks for the help!
Nate
Hall of Fame Super Red
Re: Moving CUE
Hi Nate,
The main thing here is that you will need will need to re-build the whole configuration
(including licenses) due to the fact you are moving from CUCM to CME Here is the
related note;
Note: There is no method to convert or back up and restore from a Cisco CallManager Express integrated with Cisco Unity Express to a Cisco CallManager integrated with Cisco Unity Express or vice versa. The card must be re-imaged. This means that you must reapply the software and license, and all the configuration and data, which includes voice mail messages, are lost.
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a0080289ef0.shtml
Hope this helps!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Re: Moving CUE
Hello Nate,
Regarding the voice mails and CUE configuration you can do a backup of all of them and restore them to the the CUE without any issue, this is the procedure for that:
GUI Process:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps5520/products_configuration_example09186a00802fb58d.shtml
CLI Process:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/unity_exp/rel3_2/administrator/voicemail/11bkrst.html#wpxref55929
Walter Solano
CCNA Voice
Cisco UCCX Specialist
Re: Moving CUE
Hey Walter,
I didn't think you could do this when moving from CCM to CME
or vise-versa? This seems to be the path that Nate requires.
Cheers!
Rob
Re: Moving CUE
Rob,
There is no way to migrate the configuration from you CUCM to your CME, but there is a part of the question if I don't mistake that he asked he can move the configuration from one CUE that has in a 3825 to another one
Walter Solano
CCNA Voice
Re: Moving CUE
Hey Walter,
That's true my friend, I guess we are both looking at different
parts of the same equation +5 for sure!
Cheers!
Huff
Re: Moving CUE
Rob & Walter -
Thank you for your help. What you explained makes total sense!
Cheers,
Nate
Re: Moving CUE
Hey Nate,
You are most welcome
Have a great weekend and best of luck with your changes.
Cheers!
Rob
Re: Moving CUE
Rob & Walter,
Last night we did the transition to the new 3825 with CME. We backed up CUE from the old 3825, removed the module, and installed it in the new 3825 with CME on it. We had to clear the arp table cache on the switch since the MAC changed, but everything worked! We retained all of our configuration, settings, prompts, scripts, users, mailboxes and voicemails.
I just figured I'd let you know it did actually work!
Thanks again,
Nate
Re: Moving CUE
Hey Nate,
Thanks for posting back with your results, great work! +5 points
for this good follow-up
Cheers!
Rob
475
