Hi All,
Like to get a clarity on Publisher migration to a different location part of diff subnet.:
Scenario-I: The CUCM Cluster at Location X includes only the PUB to which 200 users are registered and incase of PUB going down, SRST is there. The PUB is on a UCS C200 M3S server at Location: X . There is a new location/Site which has come up with almost 2000 users, as such, need to move PUB to Location- Y. This location-Y will be part of a diff subnet. Both Location-X and Y part of same enterprise and with in the same country.
Ques1. Please correct if any of the Step involved (moving PUB to Location-Y) is incorrect or needs to be updated:
1. Take DRS backup of PUB
2. take it out of Network
3. Install CUCM 9.1 on a UCS C220M3S Server at location Y with same Hostname, Passwords.......
4. Restore the Backup
Ques2. Another challenge is when you restore the backup at location-Y, will there not be an issue since the DRS backup was taken in a different subnet, i.e; at location-X with a diff. IP Address, Subnet Mask, Default Gateway, . How to overcome this challenge?
Ques3. If Location-X has 200 users and Location-Y has 2000 users, then ideally the PUB should be based at location-Y.
This holds true since the no. of users are more at location-Y .Also, for database sync, will not lead to explosion in bandwidth which might be the case if PUB factored at location X. Is there any other reson besides this. Please confirm if this understanding is correct, else please share your inputs.
Thanks in Advance
Sumit
