MP3 to WAV ulitity
I am looking for a free utility that converts MP3s to wav (G711u-law 8K PCM), any recommendations?
1 ACCEPTED SOLUTION
Re: MP3 to WAV ulitity
Hi friend,
Try with Switch Audio File Converter:
http://www.nch.com.au/switch/
- adrián.
Silver
Is it for greeting files? If so, here is a trial version.
http://www.avs4you.com/fr/AVS-Audio-Editor.aspx?type=GoogleAdWordsContent&gclid=CPnDuoyGypMCFQEQGgodQzZFjw
Let me know if it doesn't work.
MK
Hi friend,
- adrián.
thx for the responses
163
