MQC Cisco 3750 - dont see match "protocol"
Im using Cisco 3750, trying to classify http traffic on my 3750, however I dont see an option to match "protocol" http
3750qos#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
3750qos(config)#clas
3750qos(config)#class-map hypertext
3750qos(config-cmap)#match ?
  access-group     Access group
  input-interface  Select one or more input interfaces to match
  ip               IP specific values
Something I need to enable ?
Sylvester
Everyone's tags (1)
1 REPLY
Hall of Fame Super Gold
Re: MQC Cisco 3750 - dont see match "protocol"
Due to hardware limitations, layer 3 switches do not have the full set of MQC features like true routers.
If you look in the documentation it will tell you what is supported, or you can find using the CLI.
503
