Multi Country Cluster Device/Line Class of Service
Hello all,
I am working on a design for two Communications Manager clusters, one in the Middle East and the other in Asia. Both clusters will be servicing sites in multiple countries with differing dialing/blocking patterns for local, national, toll-free. Which makes things a little more difficult when using the device/line approach to providing class of service.
Instead of creating cluster wide blocking patterns/partitions/css, I am considering doing this at a Country level. Unfortunately this would ultimately create as many partitions/css's as using the tradational method to CoS. Im curious on what others have done in a similiar situation, pros/cons, etc..
All input is welcome, thanks in advance.
1 REPLY
Hall of Fame Super Silver
Re: Multi Country Cluster Device/Line Class of Service
Yes that is your only good option. I've done few similar deployments and this was my approach. No other good way I am aware of.
173
