Multi level access
If an admin forget the CCMAdministrator password in MLA enabled Callmanager how he can login
Re: Multi level access
In this case, you can disable MLA using SQL and then login as the administrator. See the following link.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800e1691.shtml#newtopic
Hope this helps. If so, please rate the post.
Brandon
Thanks a lot its really solved my problem
113
