02-03-2009 12:03 AM - edited 03-15-2019 03:56 PM
Hi All
can anybody has the document for Sample multi tenant dial plan
if yes kindly share
Thanks in advance
02-03-2009 07:33 AM
i'm going to assume this is for CUCM as you don't mention anything of what products you're using
multitenant design is based simply on using CSS and partitions to separate each company, there's nothing more to it on CUCM.
PT1/CSS1 for company 1
PT2/CSS2 for company 2
PT3/CSS3 for company 3
java
if this helps, please rate
02-03-2009 07:47 AM
Thanks for the reply this design is correctly right what i want is to design unified/distributed dial plan for the tenants .. hence i was looking for some standard abbrivations and if some simple document available
regards
