multi tenant PRI on H323 gateway
I have a H323 gateway with two PRIs used by different BUs within the same Unified CM cluster. I would like calls from a particular BU pick a particular PRI on the gateway. Is there a good way of accomplishing this?
Please rate useful posts.
1 ACCEPTED SOLUTION
Prefix the calls from each customer with a unique ID, then just create dial-peers to match those prefixes and discard them, pointing to the PRI you want to use.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
java
java
192
