12-29-2009 02:48 PM - edited 03-15-2019 08:55 PM
We are are trying to broadcast a message dialing from a Cisco phone 7961 to the "Genie" on a Vocera Server.
We can Broadcast Vocera to Vocera and Cisco Phones to cisco phones. But when we try to do the broadcast fro the Cisco phone through The Vocera server it never works.
Can you help....
12-29-2009 05:32 PM
How is your vocera server integrated to the Call Manager system? do you have FXO ports on the cisco VOIP gateway that is trunked to the vocera server or IP trunk to vocera? also check if you have multicast routing enabled in your Network if the vocera server resides in different network to CCM.
Do you have H323 gateway or MGCP?. try adding "ccm-manager music-on-hold" on the gateway and test.
hope this help. Thanks
Please rate if it helps.
Mohammed
12-30-2009 07:28 AM
Can you explain what you mena by broadcast? Is this a one to many type call? Three ways (or more) to do this. Is it an IP phone application, a SIP transaction or a telehpone call?
