Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Multicast MoH from SRST router not working when WAN is UP
Hi folks,
I have
ip source-address 192.168.15.5 port 2000
which is essentially the Voice VLAN configured in the router
and
multicast moh 239.1.1.1 port 16384 route 192.168.15.5 10.1.1.1
10.1.1.1 is loopback address configured on mgcp gateway
multicast is enable
ip pim sparse-dense-mode is enabled for Gig0/0 with ip address of 192.168.15.5
CUCM-HQGW--------------------------BRGW------PHONE1
                                             phone2
call manager MRGL and MoH server and Audio file source is all multicast enabled.
Re: Multicast MoH from SRST router not working when WAN is UP
Did you "debug ccm-manager music on hold" to see if the request hits the SRST router when you try to put a caller on hold?
also, does in work when you put an external PSTN call on hold.
I noticed that you use the 239.1.1.1 base multicast address, what codec is being used between the holder and the holdee? This will influence the multicast address being used. Debugging moh will tell you which multicast address is being requested (join request) by the phone to the SRST gateway.
Try this first
R.,
Please rate if this is useful
Please remember to rate useful posts, by clicking on the stars below.
Hall of Fame Super Silver
Make sure you also have global "ccm-manager music-on-hold" command applied.
I've seen issues where streaming from router would not work, and removing all related commands and reapplying fixes it.
HTH,
Chris
341
