Multicast MoH issue in SRST/CME
Symptom
I'm testing the MoH between IP Phones in the LAB (No PSTN available)
1. in normal mode, remote IP phone can get MoH from local SRST/CME router successfully
2. in SRST/CME mode, I hear ToH when press Hold button in remote IP Phone
CCM6.1.2 configuration
-g729 between HQ and remote office
-create a region to assign g711 between MoH server and remote office
-MoH server=enable multicast(239.1.1.1, port 16384, increment=port numner, max hops=1)
SRST/CME configuration
ip multicast-routing
interface GigabitEthernet0/0
ip address 10.0.29.2 255.255.255.0
interface GigabitEthernet0/1
no ip address
duplex full
speed 100
interface GigabitEthernet0/1.22
encapsulation dot1Q 22
ip address 10.0.22.1 255.255.255.0
interface GigabitEthernet0/1.23
encapsulation dot1Q 23
ip address 10.0.23.1 255.255.255.0
ip helper-address 10.0.131.11
ip pim sparse-mode
ccm-manager mgcp
ccm-manager music-on-hold
mgcp
mgcp call-agent 10.0.131.11 service-type mgcp version 0.1
telephony-service
video
srst mode auto-provision none
srst dn template 1
srst dn line-mode dual
max-ephones 52
max-dn 192
ip source-address 10.0.23.1 port 2000
max-redirect 20
system message Lost IP WAN, in SRST Mode!!
sdspfarm units 1
sdspfarm tag 1 conf
time-format 24
voicemail 3200
max-conferences 16 gain -6
call-forward pattern .T
moh music-on-hold.au
multicast moh 239.1.1.1 port 16384 route 10.0.23.1
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
ephone-dn-template 1
call-forward busy 3200
call-forward noan 3200 timeout 12
ops1srst#sh ephone summary
Active MOH clients 0 (max 196), Media Clients 0, B-ACD Clients 0
File music-on-hold.au type AU Media_Payload_G711Ulaw64k 160 bytes
Moh multicast on 239.1.1.1 port 16384 via 10.0.23.1
I exactly followed the CCO instruction but I hear ToH in SRST/CME mode. Advise please!!!
Thanks in advance,
1 REPLY
Re: Multicast MoH issue in SRST/CME
put on the source address interface
h323 voip interface
h323 voip bind srr add 10.0.23.1
if didnt work make the wource interface as a loopback interface make it the source for voip and for sccp as well and add it to the moh multicast route
also try to remove the moh config and re put it again
good luck
416
