multicast moh on Cisco 8961
I've got a c2921 with cme 9.1, a lot of sccp phones and 3 8961 sip phones. I've configured multicast moh under telephony service and everything works in all scenarios except when the 8961 is the holdee and an sccp phone is the holder. I can't hear any music on 8961.
I've loaded the latest firmware
Here is the relevant config
voice register global
mode cme
source-address 192.168.45.2 port 5060
timeouts interdigit 5
max-dn 200
max-pool 100
load 8961 sip8961.9-3-4-24
authenticate register
authenticate realm all
timezone 23
time-format 24
date-format D/M/Y
hold-alert
tftp-path flash:
create profile sync 0415346403472518
network-locale IT
user-locale IT
telephony-service
no auto-reg-ephone
max-ephones 100
max-dn 200
ip source-address 192.168.45.2 port 2000
service phone ehookEnable 1
service dss
system message Barile Flowers Service
user-locale IT
network-locale IT
load 7942 SCCP42.9-3-1SR2-1S
time-zone 23
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
moh "moh.au"
multicast moh 239.10.16.4 port 16384
transfer-system full-consult
create cnf-files version-stamp 7960 Jul 31 2013 15:02:17
I've only catalyst switches and voice vlan configured.
Thank you for your help
Gaetano
1 ACCEPTED SOLUTION
I'm not sure if this would make a difference but have you restarted the 8961?
Yosh
HTH Regards, Yosh
Yosh
HTH Regards, Yosh
Re: multicast moh on Cisco 8961
I had just to reset the phone. Everything works now!
Thank you
I too have an 8961 configured
I too have an 8961 configured with MOH running on CUCM 7.15. If I call an outside number and place the call on hold, the held caller hears music. (works as expected)
 If I call a call manager SCCP device and place the call on hold the held caller doesn't hear anything.
(Not expected)
 I've reset, restarted, reprogrammed, powered off...No change
 If the sccp device places me on hold, then I hear their programmed hold music. (Works as expected)
So there's something else going on more than just a simple reboot...
341
