Community Member
Multicast RTP to 7960G
Hello all,
is
<CiscoIPPhoneExecute>
<ExecuteItem Priority="0" URL="RTPMRx:239.1.1.1:22224"/>
</CiscoIPPhoneExecute>
enough to make cisco 7960 join a multicast group and play the audio. it is working on 7970 i'm JMF to stream wav file and it work fine but never on 7960
after executing the XML service the phone turn on the speaker and off the mic but nothing else looking at web interface of the 7960 i see
DomainsnmpUDPDomain
Remote Address/0
Local Address/0
Sender Joins0
Receiver Joins9
Byes8
Start Time0
Row StatusActive
kindly advice
Everyone's tags (2)
Bronze
Re: Multicast RTP to 7960G
Just for starters the range and port you are using is fine. We would really need a capture to be able to tell what is going on. What firmware are you using on the 7960G? I would try it with the latest firmware. Sounds like they are going into 'receive state'(muted and speaker comes on). Maybe you need to send a volume option as well? Tough to tell without a capture though. One thing you could try also is using the edge port range like 20482.
Community Member
Thanks for your reply,
i change the port as suggested, and added the vol option
here is the FW info :
App Load IDP00308010200
Boot Load IDPC03C300
Version8.1(2.0)
DSP4.0(5.0)[A0]
attached the pcab file which is ran before starting the service and after quitting.
phone ip add 192.168.10.33
pc attached 192.168.30.25
multicast server 19.168.10.100
thanks
468
