Community Member
Multilevel Precedence and Preemption in CCM 6.x
Can we do MLPP IP to IP. In the following scenery Manager - A want to call anyone of the employee IP Phone; even the employee is in the call or hold, this can be achieved by MLPP, please light me on MLPP solution.
Re: Multilevel Precedence and Preemption in CCM 6.x
CUCM supports MLPP over SIP. As well, the gateway should as well.
Here is a sample dial peer:
dial-peer voice 2345 voip
destination-pattern 2345
voice-class sip resource priority namespace dsn
voice-class sip resource priority mode strict
session protocol sipv2
session target ipv4:172.18.1.1
As well, with CUBE 1.3 in 12.4(22)YB, you can do header and SDP passing which means you can transparently pass any proprietary signaling through. While the MLPP code is not proprietary because it is designed to interop with military SIP trunks, you may find additional ease in configuration by doing this.
-nick
Community Member
I am having CUCM 6.x DN number as follows A-1001, B-1002 and C- 1003.
Here A is manager, when he call B or C, even when B& C is in other call, that call should get disconnected and the Call A should be connected.
I try translation pattern 90.100x with MLPP setting to Executive Override, this pattern can be call by only manager - A [1001] phone B&C are MLPP Indication enable premption - disable.
In IPPhone a 1001 MLLP Indication enabled, premption - disable.
But the NLPP is not working for me. I am able to call with MLPP symbol.
Please light me do I missing any thing in my config.
377
