Multiple access codes in single uc cluster
Dears,
I have a customer will migrade from Nortel to Cisco.
Nortel PBX has internal access codes between sites. If site A need to call site B should dail access code + Internal extenstion.
We will install one cisco UC cluster v9.1 and they need to use the same access code and extesions.
Please advise.
BR,
Haytham
On the CUCM under your route patterns you just specify when dialing site A you dial 8.xxxx use the following route list or gateway depends on what you have configured same for site b for instance 7.xxxx.
Voice CCIE #37771
Thanks Janse for your reply.
I have only one Custer and all phones registered to the same uc cluster no Trunks no Gateways.
In Nortel the Design is Distributed soo there are access codes between sites but in  cisco its centralized all phones registered to the same cluster.
Is there any posibility to use access codes between internal phones registed on the same cucm server.
HS
Have a look at the following link under the following heading:
Deploying Variable-Length On-Net Dial Plans with Flat Addressing
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/4x/42dialpl.html#wp1044800
Voice CCIE #37771
98
