multiple call managers controlling one SRST gateway
Would it be possible to have multiple call managers controlling one SRST gateway?
1 REPLY
Gold
Re: multiple call managers controlling one SRST gateway
By Multiple CallManagers, you are referring to one cluster or multiple clusters ??
If this is one cluster, then yes you can use the same SRST Gateway for multiple servers across the cluster.
Hope this helps
92
