Silver
Multiple CME problem
Hey gus,
I have two Cisco 3900 series CME Router with 450 IP Phones.
my topology is like this,2nd CME is connected to 1st CME and 1st CME is connected to PSTN network.
(2nd one dosnt have direct connection to PSTN)
Both CMEs can communicate with each other normally 1st CME can call to PSTN but 2nd CME cant call to PSTN(mobile phones over my country),it just gives a short miscall.
Revers is OK, i mean from mobile phones i can call to my 2nd CME's phones.
can any one help me please to solve this problem?
I would really appreciate.
Posted by WebUser Ali Hassan Elham from Cisco Support Community App
Is it possible to get debug isdn q931 logs from CME1? Also some relevant config would be great.
Please rate useful posts.
Silver
Here is CME 1 running config:
MOD-ANDU-CMERTR-101-01#sh running-config
Building configuration...
Current configuration : 89197 bytes
! Last configuration change at 09:10:51 UTC Sat Dec 22 2012 by Nadmin
! NVRAM config last updated at 12:39:50 UTC Wed Dec 19 2012
version 15.2
hostname MOD-ANDU-CMERTR-101-01
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone UTC 4 30
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip dhcp pool BLDG164ext-VLAN1645
network 10.29.53.0 255.255.255.248
option 150 ip 10.29.61.244
default-router 10.29.53.1
ip domain name CME.ANDU.local
ip cef
crypto pki trustpoint TP-self-signed-283385226
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-283385226
revocation-check none
rsakeypair TP-self-signed-283385226
crypto pki certificate chain TP-self-signed-283385226
certificate self-signed 01
30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32383333 38353232 36301E17 0D313230 35333031 36303733
335A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3238 33333835
32323630 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
D848490F 1BFE3C29 2484C84E CB53C090 A2848F0A 581D81CE 683EE653 987088D5
6C6804F6 EB8C182E 57D835C3 D177756F 61783EF9 2A5B68BB DE1C2FDB 8A6FAF50
1892950E E8960D08 DDA39412 70FB4683 456B97F3 2487EB84 A2906946 CB8113B6
777AD986 F637DD94 06376566 3BF5DC82 57FE08CA AF36675F FEEA0D42 5F223A79
02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
23041830 168014A5 C3D2DB3E FE56EABA 5EE21B01 5E147297 1B6EDD30 1D060355
1D0E0416 0414A5C3 D2DB3EFE 56EABA5E E21B015E 1472971B 6EDD300D 06092A86
4886F70D 01010505 00038181 00405F9F C2BA64B6 236590C5 A776E231 BC6F3CA9
294FDF9A 45983DC4 87CFCACB 23344E9D C031DA10 EFE36015 D956D72F 2E88D1C6
F0E0B99D 94EC3ADE 26F91D3D 2238934A 595B3E07 7A463DEB A5CCA496 8CFEABFD
F9461A86 4E744484 90F1D066 7D5FA6D5 CE3D3D3E E7F6E693 E0E25B15 8958CC3A
27186ECE 459FEDB7 1389D2B5 F5
quit
voice-card 0
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice translation-profile PSTN_ACCESS_DIGIT_PROFILE
translate called 1
license udi pid C3900-SPE250/K9 sn FOC15475ELX
license accept end user agreement
license boot module c3900e technology-package uck9
hw-module pvdm 0/0
hw-module sm 1
hw-module sm 3
file privilege 0
username cmeadmin privilege 15 secret 5 $1$vs3V$2nAHG6PK.dMmM8ibvrv4h1
username felvin password 0 1234
username Nadmin privilege 15 secret 5 $1$B.vP$cxZxiF0fgCPhAttYjhz18.
username ftsiadmin privilege 15 secret 5 $1$q74y$On22.b4n86Ihou0aAQ3P81
redundancy
no ip ftp passive
ip ssh version 2
interface GigabitEthernet0/0
description "A-160-1-3945-CME-01"
ip address 10.29.61.244 255.255.255.248
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 10.29.57.11 255.255.255.192
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
description $ES_LAN$
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/3
no ip address
shutdown
duplex auto
speed auto
interface SM1/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.29.61.243 255.255.255.248
!Application: CUE Running on SM
service-module ip default-gateway 10.29.61.241
hold-queue 60 out
interface SM1/1
description Internal switch interface connected to Service Module
no ip address
shutdown
interface SM3/0
no ip address
shutdown
service-module fail-open
interface SM3/1
no ip address
shutdown
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash0:GUI
ip route 0.0.0.0 0.0.0.0 10.29.61.241 name voip_vrf
ip route 10.29.58.128 255.255.255.192 10.29.57.2
ip route 10.29.61.243 255.255.255.255 SM1/0
nls resp-timeout 1
cpd cr-id 1
snmp-server community 21gunSaLUt3 RO
snmp-server community MOD-ANDU RO
snmp-server enable traps entity-sensor threshold
tftp-server flash:CP7912080004SCCP080108A.sbin
tftp-server flash:APP6911SCCP.9-2-1-a.zz.sgn
tftp-server flash:BFS6911SCCP.9-2-1-a.zz.sgn
tftp-server flash:KNL6901SCCP.9-2-1-a.zz.sgn
tftp-server flash:KNL6911SCCP.9-2-1-a.zz.sgn
tftp-server flash:SCCP6901.9-2-1-a.loads
tftp-server flash:SCCP6911.9-2-1-a.loads
tftp-server flash:BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:DSP69xx.0-0-0-8.zz.sgn
tftp-server flash:SCCP69xx.9-2-1-0.loads
tftp-server flash:SCCP69xx.9-2-1-0.zz.sgn
control-plane
ccm-manager sccp local GigabitEthernet0/0
mgcp profile default
sccp ccm 10.29.60.245 identifier 2 version 7.0
sccp ccm 10.29.60.244 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 2 register mtpc46413292b80
associate profile 1 register mtpc46413ddfb80
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 5
dspfarm profile 1 transcode
codec g711ulaw
maximum sessions 6
associate application SCCP
dial-peer cor custom
name LOCAL
name MOBILE
name LOCAL-MOBILE
dial-peer cor list LOCAL
member LOCAL
dial-peer cor list MOBILE
member MOBILE
dial-peer cor list LOCAL-MOBILE
member LOCAL
member MOBILE
dial-peer voice 1 voip
description "to Voicemail"
destination-pattern 7...
session protocol sipv2
session target ipv4:10.29.61.243
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 7 voip
description "To MOD"
destination-pattern 261....
session target ipv4:10.1.0.13
no vad
dial-peer voice 10 voip
corlist outgoing LOCAL-MOBILE
description "Telecom"
destination-pattern 9..........
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 8 voip
destination-pattern 262....
no vad
dial-peer voice 5 voip
description "To CME2 263435x"
destination-pattern 263435.
session target ipv4:10.29.61.245
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2 voip
description "To CME2 263436x"
destination-pattern 263436.
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 3 voip
description "To CME2 263437x"
destination-pattern 263437.
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 4 voip
description "To CME2 263438x"
destination-pattern 263438.
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 6 voip
description "To CME2 263439x"
destination-pattern 263439.
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 12 voip
description "To CME2 26344xx"
destination-pattern 26344..
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
retry invite 2
mwi-server ipv4:10.29.61.243 expires 3600 port 5060 transport udp
gatekeeper
shutdown
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 40
sdspfarm tag 1 mtpc46413ddfb80
no auto-reg-ephone
authentication credential cmeadmin Cm34dm1n
max-ephones 475
max-dn 480
ip source-address 10.29.61.244 port 2000
max-redirect 15
system message ANDU
url services http://10.29.61.243/voiceview/common/login.do
url authentication http://10.29.61.244/CCMCIP/authenticate.asp
load 7912 CP7912080004SCCP080108A.sbin
load 6921 SCCP69xx.9-2-1-0.zz.sgn
load 6961 SCCP69xx.9-2-1-0.zz.sgn
load 6901 SCCP6901.9-2-1-a.loads
load 6911 SCCP6911.9-2-1-a.loads
time-zone 41
date-format dd-mm-yy
dialplan-pattern 1 2631... extension-length 4
voicemail 7000
max-conferences 8 gain -6
web admin system name cmeadmin secret 5 $1$EM.l$kBkl2njl3sc7v/MjUZ8.71
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 1...
transfer-pattern 2...
secondary-dialtone 9
night-service code *1234
create cnf-files version-stamp 7960 Dec 18 2012 09:45:46
ephone-dn 1
number 2634001
label user1
call-forward max-length 4
corlist incoming LOCAL
Can you post your second CME config?
Are you binding your sip source traffic to a loopback interface or to the CME 2 connection to CME 1?
274
