Multiple CME problem
hi, i have configured on both of my routers 2 CME with the ollowing address:
CME 1 192.168.1.1
CME 2 192.168.2.1
and i have tried to connect these CME via a dial-peer configurations but it doesn't work ... i have defined an ip routing and i'm able to ping from each FE interface of the routers and i have defined the following dial plan:
dial-peer voice 1 voip
destination-pattern 2...
session target ipv4:192.168.X.1 (address of the remote CME)
codec g711ulaw
and i was unable to place a call between the two routers
you will find an attach one of my router configuration's and by the way i connect them using a WIC-2T cable and DTE/DCE cable thanks for your help i really appreacite it
Kindly Seifddine
no vad
1 ACCEPTED SOLUTION
Re: Multiple CME problem
On second look, it's only incorrect in one of the configs.
Brandon
You will also need incoming dial peers on each side. Such as:
dial-peer voice 5 voip
incoming called-number 2...
Hope this helps.
Brandon
Thanks but unofrtunatly i got the same prob
If you enter "debug voip dialpeer" on both routers and make the call, do you see the call hit a dial peer on both routers?
Brandon
yep when i use the debug cmd i can on both routers some results here r some of them:
from One router i called 3122 and 3... was a destination to the other router
Dec 14 17:16:08.699: //-1/9F002A04804B/DPM/dpAssociateIncomingPeerCore:
Calling Number=100, Called Number=3122, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
*Dec 14 17:16:08.699: //-1/9F002A04804B/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=2
it was like the router does't strip out the extension 3 and transfer the call to the ephone-dn 122 am i right??
thanks for ur assitance
PLZ Can anyone help to figures this thing out :)
i appreacite it
Yes, that is correct. Explicitly matched digits are stripped on POTS dial peers, but not on VOIP dial peers. If you want 3122 to go to extension 122 on the other end you will need a voice translation rule such as:
voice translation-rule 1
rule 1 /^3\(...$\)/ /\1/
voice translation-profile profile1
translate called 1
incoming called-number 3...
translation-profile incoming profile1
This will translate incoming called numbers that begin with 3 followed by 3 numbers to the last 3 numbers.
Hope this helps. If so, please rate the post.
Brandon
thanks for your help Mr Buffin but unfortunatly the translation profile doesn't work and i don't know why even more more i have tried to chek up the translation rule with the cmd test voice translation-rule 1 3100 so it shows up the right translation so i have created a DN with the extension number 3100 on the other side and i ommit the dial-peer voice to set up the incomming called number 3... and it works fine :) but i stoneshed why the translation rule doesn't work
thanks again and if u can provide an answer it would the best welcome kindly
If you enable "debug voip dialpeer" on the far end, does the call hit the correct dial peer? The one with the translation profile applied?
Brandon
yes it hot the correct dial-peer but the destination don't changed i mean there aren't any digit manipulation or translation effectued ?? it makes confused thanks for looking after my interests i really appreciate your help
kindly
Can you attach the config from both routers and the output from the debug?
Brandon
hey Mr Brandon thanks again, here r my router's configs
Kindly
Seif
Your translation rule should match your incoming called number. So, on the router receiving the call for 3100, you should have:
translate called 1
dial-peer voice 3 voip
It looks like your translation rules are reversed in the configs.
Brandon
Brandon
thanks amn what a big mistake, right now i'm at home and i'll be back to the office the next Monday i'll fix it and keep you in touch with the results thanks again
Kindly
I have changed the configuration as needed but still got the same proble here r the confs after the modification thanks for your help i really appreciate
kindly Seif
Add "codec g711ulaw" to your incoming dial peers. The default is g.729, so your incoming/outgoing dial peer codecs are currently mismatched.
Brandon
152
